Nicolasthorel
Re: Bientôt dans les shops 2021
Message par Nicolasthorel »
Enfin une stubby qui ressemble à quelque chose...
Starbard ultrakode 78
Severne S1 4.0 4.4 4.8
carve85
Message par carve85 »
c'est vrai que la stubby ne plaît pas trop par son esthétisme mais quelle efficacité dans les conditions moyennes.
J'espère que la mamba ne sera pas en reste sur ce point...pour le moment je reste en stubby 99 qui m'a encore surpris cet été...quand tout le monde trouve la session très moyenne alors qu'en stubby je le suis régalé!
carve85
FANATIC MAMBA TE 2021
DESCRIPTION
The brand-new Mamba takes the place of the Stubby in our line-up and shines with similar attributes in sloppy waves, but comes with improved performance for when the conditions turn on. The Mamba is the evolution of our Stubby line. Our Team has constantly evolved the original shape towards a parallel outline with more pulled in nose and tail sections. The result has a new look and covers an even wider range compared to its predecessor. The main functional features of the Stubby are combined with a narrower squash tail and pointy nose - which not only look appealing – they also allow quicker adjustments of your turning radius for more fun when the waves get better. Combined with early planing and great mobility through the break - you don’t have to be a snake to catch every wave on the Mamba.
Dernière modification par carve85 le 01/09/2020 22:00, modifié 1 fois.
carve85
FANATIC GRIP TE MOSQUITO EDITION 2021
DESCRIPTION
The Ultra Grip Mosquito Edition celebrates Fanatics 40th anniversary with a blend of iconic graphics from our history combined with the most successful wave shape of today! The highly adaptable Grip enables you to ride your wave – your way, without compromise. Fast and loose, the range of six shapes achieves the ultimate goal: waveriding performance with immediate response, combined with great accessibility, speed and early planing. Through last year’s subtle changes to the outline, tail width and bottom shape, the Grip offers a new level of looseness and control – particularly in down the line conditions. The most versatile waveboard we’ve ever produced works well in sloppy waves - and it will blow your mind when your spot turns on!
Dernière modification par carve85 le 01/09/2020 22:02, modifié 2 fois.
carve85
FANATIC FOILSTYLER LTD 103L
INFORMATION
You want to take Freestyle WindFoiling to the next level? Then the Foilstyler might be the choice to consider.
Dernière modification par carve85 le 01/09/2020 22:01, modifié 1 fois.
carve85
FANATIC FREEWAVE 2021
An evolution of the Stubby outline blended with our legendary FreeWave DNA, the FreeWave is the true chameleon – ready to adapt and excel in all conditions. Last season we took our low-drag FreeWave STB concept a step further and refined the nose and pulled in the tail shape, resulting in increased control and manoeuvrability that rivals any classic waveboard on the wave face. That left room to increase planing power through its rocker line, making the range clearly the most powerful FreeWave of all times! From flatwater blasting to bump & jump to waves, the FreeWave is the one board that takes it all in its stride, and will boost your level across a bigger range of conditions than ever.
carve85
DUOTONE SUPER HERO 2021
SUPER HERO is THE ultimate wave sail which is made to perform optimally in all wave conditions around the globe. The unrivaled balanced sail is the personal favorite of PWA Wave double world champion Victor Fernandez and is a real World Cup asset that is designed specifically for wave usage. Thanks to the absolutely neutral and perfectly balanced draft position, its handling characteristics are unrivaled and it remains stable and highly controlled in every situation. The SUPER HERO feels like a three-batten design combined with the stability of a five-batten one. The specially developed profile fills out very efficiently and produces high propulsion even when underpowered, which is why it’s suitable for almost all riders, regardless of weight. The SUPER HERO’s consistent evolution makes it an even better World Cup sail with an extremely wide range of use in the wave. It continues to deliver great high-end performance even in gusty and/or nuking conditions such as the Canary Islands or South Africa, remaining under perfect control with high winds and during extremely overpowered jumps. And yet it also boasts powerful acceleration capabilities at the lower wind limit, alongside an adjustable power/drive, which comes in handy when sailing in down-the-line spots like Maui or Mauritius. To achieve this extraordinary overall package, designer Kai Hopf is tasked with combining numerous individual designs into a single concept. This includes the BATTEN-FREE CENTRE, additional MINI BATTENS, the HOLLOW LOWER LEECH and our unique RADIAL LOAD SWOOSH running from the clew. Only then can this four-batten wave sail offer a wind range whose breadth is without rival. In terms of handling, the superiority of the SUPER HERO is beyond doubt thanks to its low weight. The batten rotation is beautifully soft, even with minimal outhaul tension. The top works very actively and thus supports the propulsion. Therefore you can confidently choose a sail size smaller than with many other wave sails. SUPER HERO HD Although generally sharing the same structure, the SUPER HERO HD dispenses with monofilm even in the window panel.
thegut
Message par thegut »
carve85 a écrit :c'est vrai que la stubby ne plaît pas trop par son esthétisme mais quelle efficacité dans les conditions moyennes.
+1
je roule en Freewave STB 95 depuis un peu plus d'un an, je ne connais toujours pas les limites de cette planche. De loin la meilleure que j'ai jamais eu.
Très bien ce changement de shape, la Stubby 76/77 va baisser en occase!
Nicolasthorel
Ah non mais aucune critique sur les performances de la planche!
J'ai eu la severne nano 1 et cette année la version 2 qui ressemble plus à la stubby 2 et j'en suis content aussi.
Mais on gagne nettement en polyvalence quand le vent monte un peu
je me suis permis d'arranger un peu tes post carve85 pour que les images s'affichent :-)
carve85
T'as bien fait!
la voila en 3.7 ... ca a été le jeu des 7 erreurs pour être certain qu'il s'agissait bien d'une 2021 Image
carve85 a écrit :FANATIC GRIP TE MOSQUITO EDITION 2021
DESCRIPTION
Le paradoxe c'est que c'est une ancienne déco qui va rendre la 2020 obsolète ... avec un shape qui ne change semble t'il pas = full marketing une année ou c'était l'opportunité de garder le modèle 2 ans :sarcasm: au pire ils pouvaient lancer une série spéciale 40th en édition limitée :oha:
SB 2021 en ligne !
